I am not able to convert this section view to monochrome pdf. this section view is cut from call out and it contains few vendor models. When I try to make the pdf it goes on spooling and microstation stops working. What should I do ?
Do you have monochrome checked in the print dial box? Create a pen table so everything prints Monochrome.
This is not the best solution but trying saving this in a new file or better yet reference it into a new file. Then go to Level manager and change all the colors white or gray.
Just some thoughts. I've never had this issue.
Thank you,
Roland Cyr
CE Update 7 - Version 10.07.00.39
yes the print dial box is checked as monochrome but it creates pdf in color. how to create a pen table so everything prints monochrome ?
if I try printing without raster the large section is not getting generated. this is another problem. the pdf of this section view is not getting created
I believe the Help file has information about creating pen tables.
MaryB
Microstation 08.11.09.829Power GeoPak 08.11.09.878Power InRoads 08.11.07.615
