I am wanting to change the configuration variable level from system to undefined so the print output directory will default to last location that is used. Any ideas?
Removing the definition is like defining it as nothing. To apply across all Workspaces/Worksets, find your Organization\standards.cfg file & add the following line;
MS_PLTFILES =
