Snaps invoked by keystroke
When using the 'Measure Distance' command, and at other times, when
about to place a data or tentative point, I would like to choose a snap,
by keystroke. In the popup snaps list, the names of the snaps have their
first character capitalised and underlined, which conventionally leads me
to hold down 'Alt' while hitting the key corresponding to the underlined capital
letter, eg I hit Alt-I for intersect., but nothing happens.
How can the purportedly available keyboard strokes be enabled?
I think they are enabled in the middle of the 'stretch' command.
thanks for any help
Jim
  • You may want to move this thread to the regular MicroStation discussion.
    Do you use Accudraw? You can set up Accudraw keyboard shortcuts for your most often used snap modes.
    Hopefully, if you move this thread, someone who uses the popup snaps list more regularly than I do will be along with more insight.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
Reply
    MaryB
