Pset and linetype scales
Pset is not print the linetype scales correctly.  Drawings print correctly without pset.  How can this be resolved.
On another note (maybe related), if we open a dgn as read only the linetypes scales are incorrect.
PowerGeopak SS4 v08.11.09.878
  • Opening in Read-Only mode may be the key. In Print Organizer the default is to open each file as read-only during processing.
    To change this select Edit > Preferences in the Print Organizer dialog. Down near the bottom of the Preferences dialog uncheck the option to Open design files in read-only mode.
    That should resolve this issue, but the bigger issue is why your line style scale is incorrect when the file is opened in read-only mode.
    Rod Wing
    Senior Systems Analyst
