I am new to microstation and I am having trouble with printing. I am able to get the desired output that I want, but the process is very long and cumbersome and inefficient. There must be a way to improve it right?
The problems I am having are;
1. Have to go through a long cumbersome process to get the printer set up properly
2. Microstation does not remember last print so each time I print, everything has to be reconfigured all over again
3. I cant figure out how to save the print configuration into the drawing layout so that future prints of the same drawing remember how its supposed to print (AutoCad APPLY TO LAYOUT)
4. Drawings with raster images take forever (sometimes up to 30 minutes) to spool to the printer during which time microstation is completely locked up, including other instances of microstation open to different drawings so all I can do is go get coffee and wait.
Prints must use a special printer, which is not the windows default printer. Each time I print the windows default printer is selected so I have to go to select windows printer and choose the right one.
Prints use a custom page size, so each time I have to go to configure windows printer, properties, advanced, page size, postscript custom page size, type in the size, ok, ok, ok, ok, print
Prints must be in monochrome, and most of the time the fence should be fit all so I have to select monochrome and select apply fence to fit all.
Approximately 1 out of every 10 drawings the correct fence is different than fit all. Unfortunately sometimes I forget to place the fence first and I have selected everything else and then I realize my mistake and I have to cancel out of the print and go place a fence and when I come back everything I just set is gone and I have to start over.
I have explored print organizer and print styles without any improvement. I followed a tutorial that someone posted on their blog that claimed to help you create a custom printer that is set up like you want, but in the end all I had was a print style that would do the select monochrome part for me. Which is no help because it takes longer to pull down a menu and select print style than it does to just select monochrome.
The printer and the page size never change, so if you could tell me how to make it always go to that printer with that custom page size, that alone would save a lot of time.
Even better would be if I could save the print settings into the drawing layout, like you can in autoCAD, so that I only have to tell it once whether the fence should be fit all or something different and from then on I can do single button printing, like in AutoCAD.
And if you can tell me how to make raster printing not take forever, or not lock up all open instances of microstation so that you can at least work on other drawings while you wait, that would be great!
Any help?
Thanks!
What version (e.g. v10.x.y.z) of MicroStation, or other product, are you using?
Josh Walker said: I am having trouble with printing
There's a Printing Forum where you'll get more focussed help.
You need a .pltcfg file for each printer and probably for each config.
Version is V8i 08.11.09.829 sorry for omitting that.
I will also repost question at the printing forum, good suggestion! (Edit: its already cross posted in the printing forum I guess. I suppose because I tagged it #printing ?)
How can I get or make this file? Thanks
File print then click on the magnifying glass
Pick printer.plt
Then edit printer driver configuration
Customise these settings to suit and then save as from the file menu on the above dialog and give it a new name relevant to the printer you are using. Then use the magnifying glass in the first pic to load your custom config.
Answer Verified By: Josh Walker
