Another newbie question. Sometimes, but not all of the time, when I go to copy a block (or a cell I guess its called in microstation) from one drawing to a different drawing it disappears after I accept the placement.
So for example I have a cell for a normally open relay contact. I want to steal it from another drawing, so select it from that drawing, control-C to copy to clipboard, go to the new drawing, control V to paste it into the drawing.
So far so good, I can see it and it moves around as I decide where to insert the pasted object. Then I make my selection and, Poof, its gone. However I have discovered that if I first drop the cell to geometry before pasting it, then it always works fine. But I really dont want to drop big complex cells to geometry, it effectively breaks them in my opinion.
I tried an experiment where I created a new blank drawing from the default 2D seed file. I then tried pasting various blocks into that new blank drawing. I discovered that certain ones will paste in fine and others will promptly disappear unless dropped to geometry first.
I have verified its not pasting into a level that is turned off.
So what is causing this odd behavior? How can I make paste work without dropping the object? And why does it only disappear some times but not others?
wrong forum...
Lorys
