Hello community,
since we upgraded to the Connect Edition (CE) the behaviour of 3D-PDFs changed.
Here are the problems we encounter:
Difference in file size for the same model:
Opening time for 3D-PDFs created with CE:
Here is a picture of the "unfinished render":
The interesting thing is: If we create the 3D-PDFs of the exact same model with V8i, they are smaller in file size, they open much faster (in just a few seconds) and we do not see the “unfinished render”.
Interesting Fact: Sometimes the Acrobat Reader changes to “not responding” for a short time, but that is not always the case.
Sometimes the Acrobat Reader even says: “This file cannot be shown with the Acrobat Reader. The program will close now.” (It is not the exact message, I translated it, because I am running a machine which is set to german.)
The "look" of the 3D-PDFs:
Another thing that I am irritated about is the “look” of the 3D-PDF. The one created with the V8i looks a bit more “shiny” and the one created with CE looks a bit “dull”. We use the same setup for printing the 3D-PDF in V8i and CE. Does anybody have an idea what could cause these differences?
I added two screenshots that show the different looks of the 3D-PDFs. (We imported the print settings from V8i to CE, so they should be the same for both versions).
Screenshots:
(As an example file we just put together some random pipelineworks.)
3D-PDF created with CE (looks a bit dull and not as "shiny" as the one created with V8i).
3D-PDF created with V8i (looks a bit more "shiny" than the one created with CE).
Example Files:
The example files are just a bunch of pipelines thrown together randomly, as we can not show you real projects.
To see the effects described above it is important that the files have a certain amount of equipment in them, otherwise the difference in loading times is to short to see. That is why the files are relatively big and we had to upload the to the WeTransfer Page.
Here you can find two 3D-PDFs and the DGN file they where both created from, one time using Connect Edition, the other one using V8i.
https://we.tl/t-uPt2bxGlNe
Vielen Dank für deine schnelle Rückmeldung, aber auch diese Einstellungen beheben nicht wirklich das Problem. Sind für mich auch nicht logisch nachzuvolziehen, warum hier die dpi Zahl eine Rolle spielen soll.
Das traurige ist ja, dass ich die 3d-PDF, wenn ich sie mit der Connect erzeuge erst gar nicht auf bekomme, hier schmiert mein Programm nach 5 minütigem laden ab.
Zudem ist die 3D-PDF doppelt bis dreimal so groß.
Die V8i PDF öffnet er in Sekunden. Mir ist auch aufgefallen das wenn man aus der Connect ein Plan Raster muss, und ich die gleichen Einstellungen wie bei der V8i benutze die PDF um das zehnfache größer ist.
hi I noticed in the driver your guys are still using the default compression setting Zipped I get better results in both V8i and CE if I use JPEG for the setting (see below) my pdfs are generally smaller than with the Zip setting, its worth a try...
Lorys
Hey Lorys,
thanks for your reply. I tried to set the compression to JPEG, but it did not change much and the severe difference between CE-printed files and V8i-printed files still exists.
If the model is a relatively complex pipeline model it does not open at all when it was printed with CE. Printed with V8i it takes some time to open, but it does work.
To showcase you the difference I made two 3D-PDFs of the same model, once with CE, once with V8i. Used the same printer driver in both cases.
For the model I used the files from the OpenPlant Metric Example file set, you can find them via this link: https://communities.bentley.com/products/plant/m/openplant_powerpid-files/272113 (Make sure to be logged in to see the download button.)
I used the “structure” model and attached the “working_m” file to it. The prints where created out of the “structure” file, via the normal printing dialog using “view 2” as the print view. Used the standard set up: ANSI A, Landscape mode and maximized the view, so nothing fancy here.
The printer driver I used “XM pdf – color.pltcfg” is attached to this reply.
What I find really interesting is the file size of both the prints:
V8i has 0,657 MB
CE has 1,17 MB, so about twice the size.
I notice this difference in file size for every 3D-PDF we create. It is not always twice as big in CE, but it is a noticeable difference everytime.
PDF
XM pdf - color.pltcfg
Currently using:
OpenPlant Modeler - Version: 10.09.00.74
[MicroStation - Version: 10.14.02.01]
Hello everybody,setting the compression to JPG is only useful if you want to create a raster print. For the creation of a 3D-PDF this has no effect
Hallo zusammen,
kurze Frage, habt ihr auch das Phänomen, dass eine 3D-PDF tadellos funktioniert, wenn es aus einer konvertierten DWG-Datei gedruckt wird? Denn ich hab eine DWG-Datei, die aus Tekla kam, in eine DGN konvertiert und diese dann als 3D-PDF gedruckt, hier ist alles "spitze" wie man es aus einem V8i-Druck kennt.
