Hi All,
I would like to know whether I-Plot option is available in SS4 microstation or not. If available, then how to get it in microstation.
Thanks in advance.
Abhilash,
Yes, IPLOT should show up in the MicroStation V8i SS4 file pulldown if ProjectWise InterPlot Organizer is installed on your machine and you have integrated it with MicroStation. To integrate, select ProjectWise InterPlot Organizer Configure from your Start menu. Select the Integrate button and make sure there is an asterisk for MicroStation under "Integrate Dialog". Toggle the Dialog Integration to integrate the dialog.
Jo Terri
Answer Verified By: Abhilash Panchal
This ProjectWise interplot organiser is an Add-on or with which application it will come?
ProjectWise InterPlot Organizer is a separate product.
