Hi all,
we just started a new project with OpenRoads Designer. I've setup the DGNLIB that needs to be configure the Named Boundary process for creating Plan, Profle and Cross section drawing. That is going well. I have my border, drawing model and sheet model created in my DGN file at the right scale and the annotations are fine. The only problem is when i try to print a PDF file, in sheet model, the existing ground (reference - named boundary - terrain model) is not visible in the PDF. But it is in the drawing model, sheet model. I can snap to it in the drawing model.
Any idea?
Gilles
Real quick - have you checked to make sure the level has the Plot option turned ON? I've seen stranger things than that...
Also check that your existing ground isn't actually printing as white (255, 255, 255).
MaryB
