Hi Team,
I am facing some problems while creating plots (in GRAPHS window) from the Collapse Analysis result viewer. Only the background color can be changed. The plot axes and titles are shown in green which could not be changed. The plot's color is not suitable for attaching with any technical paper/journal. Kindly provide help for changing plot color (not just the background color).
Prabir
Hi Prabir,
can you please specify what product and version do you use? This forum is used to discuss issue with printing from MicroStation as well as other power products.
With regards,
Jan
Hi Jan,
I am using SACS software's Collapse analysis module. The plot is generated by collapse result viewer.
Prabir Chatterjee said:I am using SACS software
in such case I think you should move your question (use More > Move tool under your post) to SAC forum.
Thanks. I will try with the SACS forum.
