Hope someone will be able to assist?
I had previousely a HP plotter which model is HP T1120 which the driver allowed me to select a standard paper height (A3, A2, A1 or A0), as shown on picture below.
Now I have an OCE CW500 plotter, but I don't have a similar driver that allow me to plott long plans with a standard paper height.
Many thanks for the assistance.
Kind regards,
Vitor
I don't have this particular plotter but in the print preferences in Windows for our Oce plotter there is an options link where you can create a custom page size which could obviously have a standard height. You would also need to add the custom page size by editing the Microstation printer as you appear to have done for the HP driver.
Hi Duncan,
many thanks for your suggestion however it seems that I have to define the paper size every time that I have a drawing with a different lenght.
In fact I have a plt file for the HP which allow me to select a standard hight and customise the lenght and thats what I am looking for for this plotter. Some one in the Bentley comunity share the code of a plt file for OCE CW300 which I have modiffied for OCE CW500 however it is not working and I am tring to identify the reason.
You should be able to create a custom page size with a name that then allows you to re-use it.
Set the length to the longest it's likely to be and the height to the standard. Would that nor work?
You may need to create the page size in Windows printer settings, not Microstation. Then of course, select it in Microstation when you print (or add to plotter configuration file , pen table, whatever applies).
