Printing Transparency and Dimensions
In Microstation V8i (select series 3) I am trying to print drawings that show both dimensions and transparency for shapes.  When I check the rasterized box in the print dialog I am able to see the transparency of the shapes, but the dimension arrows and lines turn white.  If I don't rasterize I can see the dimension in black, but I lose the transparency.  Is there a way both can appear when printing?
  • Your talking about the print  preview, its not a true reflection of what happens when using transparency in the dgns, I turn off the rasterise option in the tick box in the print dialog  but have it  on in the print settings/ print attributes, and in my dgns the transparency is only applied bylevel so my dims are not affected
    Lorys
    click link to PM me
