We switched from Bentley MicroStation v8i to latest CONNECT Edition, and now we can't use plotter since we always get error.
On older version everything was working fine but now we can't print with windows driver or any other bentley driver.
Plotter is installed on printserver (HP DesignJet 500) and we can print from any other application normaly.
We have tried to reconfigure pltcfg files by inserting \\printsever\printer and //printserver/printer on all existing drivers (<DefaultPrintFileName>$(MS_PLTFILES)$(basename(_DGNFILE))-$(MS_PLTMODELNAME)-<autoInc?digits=3?base=0></DefaultPrintFileName>) and we allways get error creating print file.
Any suggestions what we could do?
Path should be ok. All other printers are working normaly. We still receive unable to access printer.
Hmm. Not sure then. The only other thing I can think is that there was a problem with an early build of Windows 10 that caused a similar problem, but that was resolved ages ago.
Hi, again. One upgrade. So i tested second HP DesignJet 500 that we have, and that one is working. The main difference is that it has HP GL2 card and installed network card in it. The first one that is not working, it's connected to network via HP JetDirect 300X and doesn't have GL2 card. I will try tomorow to remove GL2 card form working plotter and install it to first one, so i can check if it's problem with GL2 or JetDirect.
I have the same problem with the same device (DesignJet 500). It doesn't work on Connect Edition. Other printers in my office works fine. Do You solve the problem?
It looks as if they had some concern about JetDirect (instead of HPGL2). That is certainly something you could look into.
A workaround might be to print to PDF, and then send the PDF to the printer.
MaryB
