Print Organizer and OpenRoads Designer - ORD
ORD - 10.07.00.056
CONNECT - 10.12.00.40
When adding file/s in print organizer from within CONNECT everything works as expected. BUT when trying the same exact steps in ORD the process does not complete and ends with a "Unable to load design file......"
Does not crash ORD but does not ever add files either. I can open a previously created pset file apparently without problem.
Has anyone else run into this problem or know of a CR to this matter?
