I just got microstation installed on a new computer, but when I try and use a .pset to do a preview, it shows up blank. When I try to print, it says that the document was not printed due to an error, along with the error:
Exception encountered inside [qv_paintExportPlot2]
Any ideas on what might be causing this issue?
I can print through the normal File > Print route, but not the .pset.
I'm running MicroStation V81 Select series 3.
Thank for for any assistance on this issue.
Hi, I have noticed such behaviour when having references attached with "illustration" mode.
To help with print, use "rasterisation" check (on).
Nikolay
Nikolay Vyglazov
