MicroStation CONNECT; PRINT TO SPECIFIC FOLDER, WHILE WORKING ON A PROJECT
MicroStation CONNECT; IS THERE A WAY TO DEFAULT TO (REMEMBER) THE LAST FOLDER PRINTED TO WITHOUT HAVING TO NAVIGATE TO IT, BY CLICKING ON DIRECTORY & THEN SELECTING THE FOLDER?
  • Lorys,
    I have been wrestling with the same problem.
    The 'Configuration Variables' dialog that you alter, using the procedure as suggested above, is the User(personal) config file and not the 'workset' config file. Therefore all PDF output files are directed to that specified folder.
    What I am expecting is that my PDF file will be delivered to a folder that is specific to the particular workset I am working in.
    When I try and make the additiion to the workset config file the definition and try to save the path to MS_PLTFILES or MS_OUT the definitions will not save.
    How can this issue be addressed.
    What is the difference between MS_PLTFILES and MS_OUT .
    Secondly there are Named Expressions in the 'Default Print Definition Name' and 'Output File Names' which  influence the outcome. How do you set these so that the PDF fininshes in the directory as specified in above print variable (MS_Pltfiles or MS_OUT).
    David.
    (Melbourne)
  • David,
    When you look at the MS_PLTFILES configuration in the manager, what does it say off to the right under Level?
    As for MS_OUT, I don't think that one exists in MSCE.  There is a _USTN_OUT variable though.  Its description is:  Base directory for MicroStation output files.  I'm not sure if that directory would take over for the MS_PLTFILES if it was undefined.
  • personally  IMHO I prefer outputs of plots to always go to my c:\temp\pdfs  so it don't matter what the project is I always know where they end up and can move them as zips or what ever  to where they  need to go later... plus printing to server  is much slower than printing to c:\temp ( well with our server it is
    Lorys
    click link to PM me
