[CONNECT] Printing Key-ins Not Working in Custom Toolbar
I have some custom tools that I've set up to call different print definition files (.pset). These worked great in V8i and I have converted them over to CONNECT by re-creating the tools and using the key-ins that were mentioned in the Help documentation. If I key-in each command via the key-in window, it works as intended. But when I execute the tool button, I get an error saying "Unknown key-in or command". Any idea what causes this? Here's what I'm trying to pass via the tool:
dialog plot; print openprintsetup PDFColorSmall.pset
  • Through additional testing, I've noticed that this only occurs with the tools on the Ribbon, not when the toolbar is opened separately.
    My tool names had a semicolon (;) in the description of the tool and this was causing issues for the DMSG ACTIVATETOOLBYPATH key-in when passed through the ribbon. I removed the semicolon and the tools worked as expected in the RIbbon.
    Eddie Giese, PE
    Production Manager | Senior Roadway Engineer
    Licensed in FL & PA
    ACEC FDOTConnect Instructor on behalf of FDOT
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
    premier-scholar-badge road-designer-badge
    Answer Verified By: eddiegiese
Reply
    Eddie Giese, PE
    Licensed in FL & PA
