how do i get connect edition to let me edit my pen tables?
I found that some paths in Connect are write protected and require admin rights to edit the files within - for my part that is the '.pltcfg's. And you are not asked to confirm admin rights upon "Save" - you are not allowed to save those files after editing in the Printer Driver Dialog. You have save the file elsewhere and then move the files over to the path (C:\Program Files\Bentley\...CONNECT Edition\>appication<\Default\pltcfg)
You can not even "Save As"
Although that may be a Kind of "protection" against unintended change I would rather be able to at least save a changed printerdriver under a new Name.
Melvin,
You get edit pen tables here -
To follow on what Gerd mentioned, if you can't save, try a save as to your Desktop.This depends on how permissions are set on your PC\office.
Tom F.
