Hi All,
I have referenced our border into our sheets and set it as the Border Attachment so that our sheet/print sizes can be determined by the border.
When using standard sheet sizes this works fine.
However, when the border is a custom sheet size such as A0+ it does not appear to be working. See below. The sheet seems to revert back to the closest fit.
My custom sheet sizes have been added to the pltcfg (attached here) 8105.cop_pdf.pltcfg andto the sheetsizes def file (also attached here)1106.COP_Sheetsizes.def
My question is what variable or setting is determining the sheet size and why are my sheets not being recognised? As per below when i turn the border attachment to none the custom sizes apear within the drop-down list. So what am i doing wong?
I am using AECOsim CE U4 - so I guess equivalent to Microstation CE11
Joey,
There's MS_CUSTOMSHEETSIZEDEF that points to the sheet size config file.
Tom F.
Thanks for reply Tom,
I forgot to mention this variable has been defined as follows
MS_CUSTOMSHEETSIZEDEF = $(_USTN_ORGANIZATION)data/COP_Sheetsizes.def
AECOsim SS6 + CONNECT U4, Windows 7 Pro, 64Bit, Intel Xeon E3-1275 v5 @ 3.6GHz, 32GB RAM, NVIDIA Quadro P1000
Works for me here. I have a 22x36 border which isn't a standard US size and it stays put. Put a plus at the end of the name and it reads that too. Did you copy a previous sheet sizes file from v8i or modify one delivered with CONNECT? You've got your sheet size\sheet boundary defined in the border file correct?
Tom F
