i have station, offset, lat, and long all input in the Borehole tab but nothing shows up on the template when i export it to a pdf. any suggestions?
This is the plotting forum. Maybe move your inquiry to an appropriate forum. Believe you're using some sort of application software, not plain old Microstation.
