I created a .pset file, set up all the settings I need to print. I defined a print style and saved. But when re-open the .pset file it doesn't find the print style I saved before. where is it saved? I though when I open the .pset file to print, I don't need to do anything else.
Hello Lucillia,
As far as I can tell the print style is stored in the design file you've build it in. So you need to go back to the design you were in while creating that .pset. It is better if you create a print style inside a .dgnlib so you can share it throughout your project or company.
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
Ivo Blaauw,
I created the print style inside a .dgnlib, but when I select the .pset on print organizer the defined print style is not there.
Thank you,
Lucilia
That's should work I suppose. Hmm, odd. Is this dgnlib stored in a location that is pointed to by "MS_DGNLIBLIST"?
