I am trying to create a layered PDF in Connect (10.13.00.48). When opening the PDF there do not appear to be any layers. When I create the file in V8i I get the Layer tree with no problems.
I am using the option <PDFLevelLabel>1</PDFLevelLabel>
Attached is my pltcfg file. I have also tried setting in the Plot dialog box Print Levels/Reference to * for Level and File/Reference and On/Off set to On. In the References tab File/Reference set to * and On. I am still not getting my Levels in the PDF (see attached).
When I select my print driver It also sets the Printer/Paper size to PDF-1 which I'm not sure what this is. My print style is PDF-Space Information in dgnlib file attached.
Any help would be appreciated...
PDFPDFpdf-connectDrvr-PrecisionHigh-TextEditable.pltcfgPlotStyles.dgnlib
Has anything changed in the current version of ORD Ce 2021 R2? I have tried to add these settings with no layers in my pdf????
I got it figured out.
