I have created a region and made it transparent. It looks perfect on sheet however when I take a plot transparency is not taking effect (even enabling it in printing setting).
Please suggest
Good day Balkrishna,
Have you tried activating the Rasterized checkbox in the print dialog? This usually does the trick.
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
I have tried and it works but does not give desired quality... I am trying to achieve it without rasterizing it..
A workaround would be to output to pdf first, then print that pdf. You can skipp the Rasterizing part then.
Can you test it in v8i? I have one or two projects that simply ignore transparency on output. I must fire up v8i to print them.
another trick to print with transparency without rasterizing is to assign a transparent display style to specific elements. Not sure which version of microstation you are using, that trick works for me in SS3.
