Issues Displaying Solids When Printing
Hey everyone, I am new to these forums.  Most of the time I am able to get myself out of trouble, but am having no luck this time around.  We use Microstation V8i Select Series 3.  Forgive me if my explanation is "cave-manish" as I do not use this program everyday.  So here is my problem:  I place a fence around a reference in my sheet file to print.  If the reference has a solid shape in front or any other solid or line or surface, the solid will not show up in the print preview, or physically print out.  I have tried checking "rasterize" but with no better results.  So as an example, if I drew 2 shapes next to each other, then placed a solid cube in front of the left shape, and placed a solid cube to the side of the right shape.  If I attached the iso view in the sheet file, then fenced it and looked at print preview, the cube in front of the left shape would not display, but the cube beside the right shape would.  Its like there is some conflict where if a solid is covering another element in view, then the solid is not displayed.  Anyway, I hope someone can lead me in the right direction on this issue.  I tried to be confusing as possible hahahah :)
