So today I was using a filled shape, transparent to highlight text within a box which has a filled background. It looked fine on the screen but a couple of the shapes didn't print as displayed (hid behind a "white" filled shape). Easy enough to fix, but what ever happened to WYSIWYG? Another Connect "feature". CE u13 10.13.01.01 on Windows 10 pro 64bit.
For transparent fills you have to toggle the Rasterized checkbox on the print dialog to see transparency on the printed output.
Rod WingSenior Systems Analyst
All my print config files are outputting rasterized, this is something else. This issue happens rarely and for no reason I can discern.
