Good afternoon,
When I plot a PDF print my text does not print.
I have 3D saved views referenced into a 2D DGN, then notate over the top.
My Active Design File sequence is slotted at the bottom of the table in order for text notation to show up over saved (3D) views (set to Hidden Line).
If I turn off the references then the text prints.
Same file seemed to work fine in SS3.
Can this be resolved please? thanks.
I have since used the Drawing Composition - Place section call outs to generate Saved Views and REF'd Models and has partly fixed it. BUT, I'd still like a solution to using conventional saved views...
Further to this.
The update sequence definitely has something to do with the plotting issues. So the Active design File needs to tbe at the top of the list. This however "blocks" all annotations or other line work that's live in the model, behind the saved 3D referenced view (which has black fill in it).
