Hi there,
I have a DWG file from AutoCAD.
I made a couple blocks that have a 3D Solid with Attribute Tags.
When I import the DWG into Bentley View Connect I can see the tags.
However, when I print to 3Dpdf, none of the tags or block name come into the 3Dpdf document.
I even clicked the Tags option in the 3D pdf print settings.
What I need is to click a model, and have the tags show up in the "Properties & Value" section of the 3Dpdf.
How could I achieve this?
I uploaded an image of the problem along with the dwg file. I made an Attribute called "ID" with random values.
AutoCAD shows it on the right, but the View Connect 3Dpdf drops it all completely.
I'd imagine this would be pretty critical for several people that not only need their models but also have to have the associated meta-data/bim to follow with.
Unfortunately, No properties and just a model make the 3Dpdf somewhat useless for most of our clients; it’s a dealbreaker ;(.
I appreciate the help.
6646.Drawing1.dwg
PDF
