Creating links inside of a PDF from sheet to sheet - MicroStation or External Application?
Looking for an end product (PDF) that has links from one sheet to another sheet. Not sure if best to accomplish this with MicroStation during the sheet creation process, or through an external application in the PDF itself, such as BlueBeam. Example: On plan sheet 20, which is a construction plan sheet, have a "linking icon" that takes the user to sheet 40 that contains a detail for a special item being constructed.
