When I print this file to pdf, the entire page goes is gray. I have only this problem in certain files with reference models but not on all of them.
Any suggestions on what I can do to fix this?
A said:When I print this file to pdf
There is a Printing and Plotting Forum, which might be a better place to post your question. You can move your post using the More|Move button.
Good Afternoon Arman,
Could you post your pltcfg file and your dgn file with all the References.
One quick thought, are you creating a 'layered' pdf? Is it possible some of the layers are 'off'' in the published pdf.
Good Luck,
And your PenTable too!
is it possible you have a large filled shape with some transparency.. please post a copy of an offending file and its ref, the .pltcfg and pentable your using so we can examine whats causing it..
Cant really work off screen shots for something so complex there ae loads and loads of variables and possibilities and settings involved.
Lorys
