In the Edit Pen table how do I create a different output weight for the text & the terminators in a dimension.ExampleDimension & extension lines width 0.15mmText & the terminators width 0.4mm text & the terminators.
Different levels? Different colors?
Microstation doesn't, by default, see the "parts" of a dimension as separate entities - the whole thing is just "dimension". If you want them to print specially, then you will need to "break them out" in a way that the software can "see". Color may be one way to make that happen. But I'm not sure - dimensions are kind of a "black box" that don't like to be broken into bits.
MaryB
you need to rebuild your dimstyle to reflect this then update your dims if your doing it to a lot you can batch process.. not easy with pentables
Lorys
Thanks for that.
In my dimensions I have lost the handles on the extension lines
BTW this is the printing and plotting forum, your question is about dims and modifying them you may get your post redirected...
In anycase :
If you draw a line can you still use the handles? Some times we turn off in error...
Are your dims set to association?
Can you make a dummy file and upload here .. take screen shots of settings too...
