Hi
Can anybody advise whether it's possible to set up MicroStation to allow dgn files to plot through a Canon imagePROGRAF TX-3000
Should be. Many of us find it much easier to use a standard format like PDF, then send that to the appropriate Windows printer. To go straight to the Canon use printer.pltcfg, select the appropriate Windows printer, set it's preferences and go.
We run a TX3000 and a TX4000. Works OK. Make a new pltcfg for your needs and go.
When using transparency in a dgn, you should remember to check the Rasterized option in the print dialog or else it won't recognise transparency. Rasterizing is pretty time consuming so you're faster going through pdf.
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
