Im trying to print a set of drawings using Print organizer. The linework is heavier when I batch plot then when I print each sheet separate.
I am using the same Pen Table when printing both ways though.
Anyone have an idea of the problem?
Im only starting to use microstation again after about a 20 yr break. So, Im guessing Im missing something simple
The idea of Print Organizer is to save a list of models to print, as well as output settings. Creates a .pset file to be used over and over.
Create a new .pltcfg (copy the one you normally use) , edit it to use your Pen Table, then use that .pltcfg for PO (and single sheets as well).
You can define a pen table to be used right in the print definitions settings
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
I did this
Thank You, This may be the fix. I will check it
Should have warned you, my approach is a bit old school. I don't use print styles, sheet index, view groups, don't need them.
