Hello all,
I am having issues printing drawings from OpenPlant Modeler Connect Edition. I am using the same pen table I used in OpenPlant Modeler Connect Edition V8i. Please see below for differences...
Printed from V8i...
Print settings from V8i...
Same drawing printed from OpenPlant Modeler Connect Edition using same pen table...
Print settings from OpenPlant Modeler Connect Edition...
Any help would be greatly appreciated...
Mike Oxyer
Sr. Designer PRVN Consultants
Lorys,
I have checked all attribute settings in both V8i and CE and they are the same as far as I can tell.
Looking at the Print dialog images V8i has Color:Grey Scale whereas CONNECT Color:True color, does changing this make a difference
Carl Myhill
Technical Support Engineer
Bentley Systems
Yeah I noticed that as well. I changed the setting to Grey Scale and there was no difference...
what does it look line in the dgn file on screen not the print and what does the level manager have, also overrides in level manager
Can you post a section of the dgn in question... I can open in CE and try it.. sorry no open plant... I still suspect you may have to rebuilt your pentable in CE, as it doesn't seem to behave... Historically Bentley doesn't recommend reusing print drivers and pentables from previous versions into new versions....
Lorys
