We have been using batch print in Microstation SS2, SS3, and SS4. Now with the move to Connect Edition we are migrating to Print Organizer. We used to have a function key set up to launch batchplot using "mdl load batchplt" is there a similar command we could put in function key menu file that would launch print organizer?
Thanks,Neal
assign the key-in <printorganizer dialog> to a function key
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Neal
if you are using V8i then the command is
mdl keyin Bentley.MicroStation.PrintOrganizer,PrintOrganizer PrintOrganizer dialog
This will not work in CONNECT and as yet I have not found the keyin.
Ian
Correction on this. You first need to run the key-in <mdl load bentley.printorganizer.dll> then use <printorganizer dialog>
Answer Verified By: Neal Styka
Thanks once we typed in mdl load bentley.printorganizer.dll;PRINTORGANIZER DIALOG we did get it to work. It took a few tries but it works great. Thanks.
I was looking for Connect Edition and Mwlong's suggestion above did work.
