I am using the Home Use Version of Microstation 95 that I received before I retired.
It has worked very well over the past many years .
Recently my HP Designjet 70 rolled over dead and I replaced it with an HPT125.
My problem is that the plots I generate for a 24x18 output are cut off. The print/plot preview shows the full drawing with proper size, borders, etc. but the actual plot is only the lower half of the drawing at the top of the page.
I did not have this problem with the Designjet 70.
Can anyone offer advise on how to resolve the problem?
I may not be much help...95 was a long time ago.
What PLT file are you using to print? It's possible that what you had been using doesn't "speak" the same language as the new printer.
MaryB
I am using printer.plt dated 11/20/95.
Would you be able to post it here so folks could look through it? I don't know if there's much to be seen, but it's worth a shot.Do all your other software applications print to it alright?
On Mar 10, 2020, at 1:01 PM, MaryB <bounce-c6d6be63-61c9-4e82-8b2b-2e2ead5ec584@communities.bentley.com> wrote:
 <Bentley_5F00_Communities_5F00_RGB_5F00_Stacked_5F00_244x88-png_2D00_125x44-png> Update from Bentley Communities <4TFHLUYLTDOK-jpg_2D00_70x70x2-jpg> MaryB Would you be able to post it here so folks could look through it? I don't know if there's much to be seen, but it's worth a shot.Do all your other software applications print to it alright? View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
I'm glad you figured it out!
