The variable MS_PLT_ENABLE_SCALE_CLIPPING states that plots will not be clipped if set to "0". Refer image below.
Has anyone else noticed this setting is not honoured in CE for all situations?
e.g. If I FENCE an A1 in DESIGN MODEL, set scale to 1:1, and review the preview, the origin reflects the size to the sheet size selected and it looks fine, but the resultant PDF is clipped
I have only just noticed in U13.1, but it may have been evident sooner. NB. Does not occur for plotting SHEET MODELS as these are driven by the SHEET SIZE
As far as I understand the variable, this should not be the case, or are DESIGN and DRAWING MODELS different in their actions?
