Hello, I am currently trying to print a map out. It has to be printed on 36 in paper width and whatever length the overall map is to be. However, I have no idea how to accomplish this. my plot diver is set up for standard ANSI size printing. Any ideas on how to print a scroll out?
What version of Microstation & what type of plot driver are you using, .plt, .pltcfg? Are you printing to pdf or direct to printer?
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Microstation V8i select series 10 using a .pltcfg to print drawing to a PDF.
So you took the Bentley supplied pdf.pltcfg file and modified that for what you need? For your printing preferences ensure that Allow Paper Size Editing is enabled. This will allow you to change the paper size right in the plot dialog on the fly. So even though you may pick a paper size that is set as 22x34 you can change that to whatever you want.
you also need to consider scaling , what I do is draw a rectangle the largest std size width for me in metric its AO which is 841mm x1189 mm
now we draw in metres so if I draw the sheet boundary as 841x1189 m its already 1:1000 for plot down to paper size A0..
now I place this over my map and determine if it need scaling up or down and also stretching length so lets assume it was wide enough but needed to be 2000 m long , now I know to create a custom sheet 841x2000m and it will be 1:1000...when plotted to paper... you can work out different scales your self this way...
I also edit the printer to have these handy rollplot paper size for future roll plots, A0x1500, A0x2000, A0x2500, A0x3000
Lorys
That's how we did it at my old workplace. We just defined a few paper sizes for several different scroll plot lengths, and (I believe) there was a setting on the printer to conserve paper by not using any more paper than the plot actually needed.
MaryB
