When I try to run print organizer the menu does not load. It was working fine in the morning and bombed-out later in the day
I notice in the message center it says
Printer print style '30x42' applied.
Default print style applied.- 30x42 (c:\cad\workspace\standards\dgnlib\cw2016.dgnlib)
I am able to create single plot files with the print command
Version v8i 08.11.09.829
I know I'm not going to get any support on this from Bentley because it's not Connect edition, I personally think that is an awful business model. You have a product that still works and thousands are still using until you get Connect bugs worked out. ( At least that's the gist of what I'm reading) In my humble opinion, I get the feeling like we are testing a beta version. After decades of promoting Bentley software, I can say I can no longer do so. It's Heartbreaking
Kirk
I Wish Cadland was Reality
for the benefit of others with the same plight in PO falling over and still running v8i...
You are not screwed you can still batch print via the old keyin mdl load batchplt.ma
The old batch plot mdl is still there just not from a pull down menu.... it still works great and fast... Bentley don't want you to use it and removed from menu to try to direct you to use PO but hey if PO don't work anymore and you cant fix it then use what does work....but what will happen in to you CE when and if PO falls over there … then what?
Lorys
Kirk said:After decades of promoting Bentley software, I can say I can no longer do so. It's Heartbreaking
me too.
You can still file a service ticket.
I breaks my heart to say so but ....Me three ..
Bentley your losing your best salesmen and promoters ... us long time users!
Well said Lorys. Perhaps Bentley should chime in and take note.
