Hello!
In all versions of V8XM and V8i tif driver (tif.pltcfg) has a problem.
If you set any resolution and then you print, the result will always be of 3072x2304 pixels.
Hi Matteo, I have not been able to reproduce the issue you have described here. For me, and the data I'm testing with, the pixels numbers change correctly with each resolution adjustment. Are you saving your edit changes to your printer driver configuration file and reloading your printer driver configuration file (tiff.pltcfg) after you make your edits? Perhaps if you attach a copy of your tif.pltcfg to your posting and the steps you are using to make and implement your changes, it may give some additional clues to the cause of your issue. HTH Jeff
