Print Organizer does not currently support ustation.exe command-line workspace customization, although a priority build might be available that adds that capability via a configuration variable. Bentley Support can offer more information on that. Refer to CR 262657.
In the commercial release, you would need to remove the command-line options and launch ustation.exe normally (which is how Print Organizer launches its background MicroStation process). You could modify the standard mslocal.cfg to use your customized settings.
You can still run the Batch Print cmd, mdl load batchplt.
You can put Batch Print cmd in a key-in, or as a modification to "File" as a site/network task dgnlib pointed to by MS_GUIDGNLIBLIST.
