Create pdf file with clear line when zoom in
I have my pen table set up where it looks good when print at the size created. However if I open the PDF and zoom in the lines are too thick to view.
In Bluebeam and Acrobat there is a setting to turn off the line widths  so the file is legible when zooming in.
Is there a setting to control this when creating the PDF so weights are clear when zooming in?
  • Hi Kirk.
    No zoom weight in cad to pdf sorry that's a GIS feature in GIS view only not make pdfs but in Mstn  you can just make pdf  no weight
    In the print dialog >settings> print attributes > untick lineweight… but msnt  will remember this next time so I recommend make a custom printer pentable  and set everything to LW=0 for output and rename it LW0 so you remember it and create a custom pdf called the same and force path the pentable…
    You can make a copy of the printer  and modify the design weight settings to all equal the same no of dots, you will need trail and error... but I think the easiest is a zero weight pentable if you plan to keep doing pdfs like this
    only trouble is its 0 weight zoom in,  is when not zoom in ie 100%  line work too thin when zoomed out...
    to make what you desire would require acrobat to create extra feature for magnification factors to only use 0 lineweights  for zoom factor x% and above I don't think they will when just control 5 toggles it on or off
    So  one just has to educate users how to turn on off lineweights  in the viewers if you want to keep line weights in the pdf for zoom 100% to stay...
    Lorys
    click link to PM me
  • Thanks lorys
    I have been using the setting in Bluebeam to toggle of line widths off for now. However that isn't going to help the client unless they do the same setting in acrobat or Bluebeam.
    Kirk
    I Wish Cadland was Reality
  • Simple would be to create a new pltcfg file and adjust the weights to values appropriate for the anticipated view scale.
    Mine
  • Bob, I have the pen weights assigned in the output by symbology by color.  Viewing on the screen and viewing on paper are different. If we were just viewing on screen I would narrow up all my pen widths but we work off of printed drawings and so do our subs in the field.
    Kirk
  • Yes, never used Turn Off Line Weights in Acrobat. I can only tell you that you have control over the output thickness thru the plotter file, pen table, etc. The display in the Microstation file is totally independent of that (weight is just a value) and can be controlled thru preferences.
    In my world folks are more and more using only the electronic file (PDF), so I make those reflect a printed page. Gave up the old standard, stupid CAD standard color output as weight (worked well in the 80s and 90s). So my CAD file, as well as the output reflects the intended presentation. Or CADland as Reality! Background is white (did not work well with CRTs), black line is, you guessed it, black.
