What is the option to print transparency in good resolution? When I use reasterized mood, the resolution of PDF is very bad.If it's concern with printer , which pdf printer driver is best for printing transparency in micro-station connect edition?
Well much depends on the data you have and what your desired output is. For me, I use a lot of orthophotos with resolutions in the 2"-12" pixel range. My output is generally in the 1:250 to 1:4000 range. I use the following settings in my .PLTCFG file.
