I created a Print Organizer in Microstation v8 and tried to print my files to PDF. Some of them printed without borders, although the border was set up the same way in all files. Is this a common problem that anyone knows a fix for? Thank you!
Natalya,
If you preview the files with the missing borders in Print Organizer , so they show up?One thing to check in Print Organizer - on the Advanced Tab, make sure your user and workspace are set correctly.Note - this will not be a problem if you are using ProjectWise
Tom F>
Thank you Tom!! I set up the workspace and the problem was solved. Interestingly, I am working in ProjectWise.
