Printing my file to pdf: I change the paper size to 11x17, select file>print, change printer to Adobe pdf and select print. The paper size then changes to 44x34 which to begin with isn't even an paper size option. I have a work-around where I cancel this print in the window where it asks where to save the file, then I change back the paper size to 11x17, repeat the process and it prints fine to 11x17. The work-around doesn't cost me much time but it would be nice to not have to go through this process every time. Any guidance greatly appreciated.
Nate,
Which *.pltcfg are you using? Printer.pltcfg?
Tom F.
Tom,
I'm not exaclty sure on that. The drop down above paper size it set to windows driver. We don't print any 3D drawings in my office. I'm thinking it must be a user specific problem because everyone else in my office uses the same version and prints just fine.
You must change printer first, then select page size, the maximize or adjust scale as needed.
Answer Verified By: Nate Proffitt
You're the man Bob, that works! Thank you
