I have asked a similar question here, but others in my organization are having the same issue. The MS version having the issue is SS4 - 08.11.09.867.
I have gone through the proposed solutions in the previous post and more, including:
The linestyle shows up in the dgn file but when printed to PDF it is a sold line. The pentable does not change the linestyles.
Are there any other possible solutions to this issue? Thank you!
The lines in question are the Sd1-S lines.
It's frustration that a lot of folks are not getting WYSISYG printout. Often it's pen tables, could be print syles or the files may have the linestyles off in file properties within the Print Organizer..
The files in the PO are set to plot linestyles.
The pentable being used does not change the linestyles, and we have tried using a different one.
Our microstation is started with the following target:
Answer Verified By: Taylor Brownlow
