I have no problem with transparencies within the layout view but once I attempt to rasterize in order to 'print to PDF' or 'print' it does not work. Any ideas on how this could be fixed? When I rasterize transparencies on generic fill shapes it prints fine.
Any suggestions are appreciated.
Richard Duncan said: once I attempt to rasterize in order to 'print to PDF' or 'print' it does not work
What do you mean by 'attempt to rasterize'? Why not simply print using a PDF print driver?
By the way, there is a dedicated print Forum.
When I print to PDF the output does not show transparencies. This is only a problem when I rasterize work which includes a .dxf file.
Thank you for informing me of the Print Forum.
in the print dialog try turn off rasterise ( tick box) and in print attributes turn on transparency should work fine on dgn and I assume should now work fine on dxf, alternative convert your dxf to dgn see if fixed, if so then its dxf that causes the issue...
Lorys
