I have some problems when trying to resymbolize my graphical elements on printed output. I use a pen table that remaps all my elements. Unfortunately the line styles are not printed with my setting from pen table. Is there another setting I have to change?
Kind regards
Marcel
What is your element selection criteria? Are you sure that the element is being "trapped"?
MaryB
Hi MaryB,
my element selection criteria is set to trap elemnts by level. The color of the lines are changed with my tbl file but the output style is ignored.
It seems to be a bug (or another setting?) in MicroStation Connect Edition (Update 14). If I use the same file an pen table in V8i SS10 the line style is changed as configured in my pen table. Maybe someone can comprehend it?
Please post sample file, containing the line in question along with the Pen Table for review
Carl Myhill
Technical Support Engineer
Bentley Systems
This is an example that shows that the color is changed with tbl file but the style not.
style_change_with_pen_table.dgn test_connect.tbl
Thanks for posting the files, I am able to reproduce this here and will have this reviewed / file a defect if required.
The same files using in MicroStation V8i SS10, work fine. I also noticed that in View Attributes if you turn off 'Level Overrides' then the style will appear solid in the View and Print.
Answer Verified By: Marcel Pradel
