We have upgraded two projects from SS4 to CONNECT and are now discovering that we cannot open the .pset files that were created using Print Organizer in MicroStation SS4. Can anyone tell me if there is a .pset compatibility issue between SS4 and CONNECT?
I don't know for sure, but it wouldn't surprise me. Many parts of the program were rewritten for CONNECT.I have no idea why they wouldn't work, but it doesn't surprise me.Hopefully one of the Bentley people will be along to give a definitive answer.
MaryB
Dave, you should be able to open your .pset files created with either version of MicroStation. More than likely the MicroStation Message center is giving you some sort of an error. Can you please look.
you might be able to load and run but you might not be able to edit ie add or remove drgs.. have you tried to make a new pset in connect to use the same drgs? and does that work?
Lorys
