Hello All, Has anyone come across this issue in Microstation V8i Select. Using the fence tool to grab the title block but I get no preview as I normally do. I do get a preview when I click the preview button and it prints fine to PDF. Not sure what caused this to happen.
I've not seen this before does it happen on all drawings?
Does it happen with all print drivers what about windows driver?
What about out of the box untouched original Bentley pdf driver?
Could be a video card / driver issue.... have you admin access to do Repair mstn from the control panel?
Can you rename your user.upf to user.oldupf and let mnst rebuild a new one..
Does it still happen? If yes then close and restore your original upf.
If no then you fixed it and it was that your user pref file got corrupted ( but we don't know why or how) and you now need to re set it up how you want your mtn preferences to work / look.... after this is working the way you want make a copy of it in your personal docs folder so you can always bring it back.. again no idea why or how.. but a back up will save time getting it working again...
Lorys
