We are using PostScript Printer Driver (i.e. Ghostscript) to generate PostScript output files with ProjectWise IPLOT Server.Since last week it doesn't work anymore. A valid PostScript file is not created. I suppose because of an Microsoft OS update.
The Bentley suggestion to DisableServerFilePooling with registry key doesn't help.
Is anyone here with the same problem?
Hi Gnoth,
We have been facing the same issue after the windows Update. Have you solved this issue now?
